windburner
Established
- Joined
- Sep 24, 2019
- Messages
- 54
geeksville said:If there is a big problem with this release I'll quickly push out a new build ...
Thanks for the 'extra-mile/kilometer' support! I'll give it a try.
geeksville said:... This new release ... version is 0.5.0-beta-4. ... We look forward to your reports of great success (or failure, ahem) in this thread.
stefkrger said:I just flashed my SW 102 according to the wiki. The log said everything went fine but the display does not come up at all.. is there any way to check if the display is working without connecting the motor? Should it come up when I connect the ST link v2 3.3v and GND or do I have to wire the display to the motor first?
windburner said:Presuming that this is the initial flash (of the bootloader and v0.19.x firmware via the wires). On the initial flash, after successful completion, it is supposed to start running a simulator and display as if it is connected to the motor, which it did for my case. If not, sounds like something went wrong.
Info screen 2 has only once entered the configuration mode for me.
stefkrger said:Is there any advantage having it connected to the motor power (like in the wiki) as opposed to the 3.3v from the stlink?
bikelpl said:I also noticed that, when You press M button and return to main screen , the assist level digit dissapears.
geeksville said:windburner said:Nfer said:I tried to open the sw102 cutting the glue at sides of the keypad and I killed the down button contact. It was my fault, instructions are good. Is it possible to use the display without the down button?
The Down button is critical for the configuration process, as well as adjusting the Assist Level, so, I'd say no. Can you solder in a wire or something to bridge the break? (I know it is tight working, as I hope to never have to mess about inside my SW102 again.)
If you do need to fix your button, you can try removing the PCB (it comes out with a little connector on the back - just flip the black tab up to release the cable). This should give you better access to plug in a jumper. But if that won't work, yeah you'll need to plunk down another $35.
hefest said:I've just ordered sw102 and while looking for the instructions how to flash it initially I've noticed that instructions how to open sw102 from the side, without destroying keypad waterproofing are nowhere to be found. I clearly remember seeing it on github but it's not there anymore. Am I missing something?
geeksville said:... new release ... version is 0.5.0-beta-4. ...
I would say you have no connection on SWD pins. Verify again your connection on SWD pins to the SW102 and try again.stefkrger said:So I've just tried the flashing again.
The device is still not coming up after the routine.
Everything looks pretty similar to the screenshot in the wiki entry, however I've noticed a slight difference (marked in the picture below). In the wiki screenshot this line says:
info : nRF51822-QFAC(build code: A1) 256 kB Flash
What could be the issue here?
I just removed the soldered wires and tried with the solderless method using a 2mm 1x4 pin header. With that method I could not get a connection. Then I soldered the wires again and now I‘m seeing the same log output as in the screenshot I posted earlier.casainho said:I would say you have no connection on SWD pins. Verify again your connection on SWD pins to the SW102 and try again.
Then I would say you have a faulty unit.stefkrger said:I just removed the soldered wires and tried with the solderless method using a 2mm 1x4 pin header. With that method I could not get a connection. Then I soldered the wires again and now I‘m seeing the same log output as in the screenshot I posted earlier.casainho said:I would say you have no connection on SWD pins. Verify again your connection on SWD pins to the SW102 and try again.
It seems it does flash something and the connection check works as well. It’s just that my display does not turn on..
I’m afraid so.. however it will be quite hard to return with the cut open side :lol:casainho said:Then I would say you have a faulty unit.
As far as we know, should work in every SW102 coming from the factory.obcd said:Will it work on any SW102 to reflash it over bluetooth (when that method is ready), or will we need one with a specific firmware to start with? I assume it needs to have a bootloader with bluetooth enabled, but it's unclear if they all use the same bootloader at the moment?
hefest said:Opened sw102 and about to solder the wires and flash it for the first time.
At the moment i have some older 0.19.x version of the firmware on the motor. Can I flash latest 0.19.x sw102 and will it be compatible with the current firmware on the motor?
