toddbailey
10 µW
- Joined
- Jun 28, 2020
- Messages
- 6
How do I balance 4 12 volt battery packs? these are sealed LiFePO4 batteries in a 4s config with their own internal BMS, similar to a drop in 12 volt replacement battery
I'm using a charger designed for 54 volt LiFe batteries but it doesn't offer balancing electronics like a separate 14s BMS would offer.
Right now I use a DVM and a 12 volt LiFe charger and charge the lowest bat to equal the others. But what would be desired is having a equalizer/balancer rated for 4 12 volt batteries instead of 4 3.2 volt cells
