Lateksinen
- Joined
- Jun 19, 2017
- Messages
- 14
999zip999 said:I read thru but can't find what motor controller you running ? A link ?
I'm running the original BBSHD controller, haven't done anything to it.
fechter said:The BMS can trip due to a cell voltage being too low or due to current being too high. If the current was too high, I'd expect it to trip right away when you give full throttle. The pack voltage looks OK with no load.
If the BMS is accessible, you can measure the individual cell voltages either on the connector or on the row if resistors that do the balancing. If one cell is significantly lower or higher than the rest, it can cause the kind of behavior you are seeing.
999zip999 said:The ez way to track your batteries problem is to write down on paper like these to show state of charge.
1. 3.90v
2. 3.88v
3. 2.99v
14. Xxx volt.
It makes it ez on all of us.
fechter said:It's hard to say, but I'd guess there is a short spike in the current that is tripping the BMS over current protection. Most of these BMS circuits respond very quickly to over current. One test would be to bypass the BMS long enough for a test. A wire from the battery negative to the pack negative on the BMS will keep it from turning off.
I had a similar issue with one I was using. I ended up adding some resistors to the BMS shunt to increase the current trip point and it's been good since.
