Hi, I'm looking for a clear answer on how to connect a BMS to a load and charger?
This forum seems to have a lot of knowledge about rechargeable power cells.
I'm not building a large power supply, but using 18650's for multiple electronics projects.
The question is on how to connect the cheaper BMS boards, that only have P- & P+ terminals.
Example: http://www.ebay.nl/itm/NEW-4A-6A-PC...attery-Cell-/201421276209?hash=item2ee5a4c431
I would like to charge and use small series/parallel setups of 18650 batteries as a power source for my projects.
Being able to recharge them without disconnecting the battery would be the goal, so the device would continue to operate.
If that is not possible, then the question would be, how to wire the P- & P+ terminals for Load end Charge.
Does a simple toggle switch suffice to change from charge to load?
Then an extra question about the charger:
I have a CC/CV PSU.
Does it need to be set to CV with "the number of 18650 * 4,2 volt" ?
And the max current set to Number of 18650 in parallel * 1C?
So if the 18650 is 2200mA/H and there are two in parallel and 3 in series (2P3S) then voltage should be 3 x 4,2V = 12,6V with a max current of 4400mA?
Thanks to anyone who can clear this up for me.
I have a CC/CV PSU.
