I have very little experiance with type of motors, sizes, styles and need some guidance.
I needed a 12v DC motor high tourque low rpm motor to spin a piece of threaded rod
I purchsed This unit off of amazon for under 10 dollars.
12V 6RPM High Torque DC Motor, Mini JGY 370 Motor Worm Gear Motor, Low RPM Reducer Motors Micro
I made up a couple pullys used a large O-ring for a belt and it does the job, I had to wire in a PWM to adjust the speed but it seems to work OK
I was hoping for somthing a bit less noisey, even with no load on it this loud. ( you get what you pay for)
I am hoping somone with more knowledge and experiance can suggest a better quality or more reliable manfacturer that has somthing similar that does not sound like its going to take off, or blow up?
12V 6RPM High Torque DC Motor, Mini JGY 370 Motor Worm Gear Motor, Low RPM Reducer Motors MicroI made up a couple pullys used a large O-ring for a belt and it does the job, I had to wire in a PWM to adjust the speed but it seems to work OK
