orangejuice
- Joined
- Sep 30, 2019
- Messages
- 4
Hello friends,
I wanted to put in series my e-bike battery 36v 8ah Li-Powith another 16.8v 8ah Li-Po. The smaller battery has the same properties as the original bike battery except the producer is different and the original battery 6 months older. I wasn't sure if the smaller battery might discharge a little earlier because of the slight differences. Both batteries do have a BMS installed, but I've read that some of these might not work together every time.
Is it reasonable to trust that both BMS will protect the batteries against over-discharge? Or is it better to add a volt meter to be sure?
If someone probably has a second to give a hint, I'd be so thankful.
Thanks so so much in advance
