crossbreak
dont make him poor.. even if he'd own a printer it would take years ankd cost $$$ to make a piece of that size...good idea, but 3D printers are not so far yet..sadly..
Exactly, 3D printing isn't much of a solution here at all. There's far more practical methods to produce plastic parts in quantity.crossbreak said:dont make him poor.. even if he'd own a printer it would take years ankd cost $$$ to make a piece of that size...good idea, but 3D printers are not so far yet..sadly..
Yes, nickel.crossbreak said:what is your tap material now? I wont have taken the steel i guess.. nickel?
Well, my target selling price for 12s6p is $89 (which I still have not reached yet). For 20s14p it would be proportional to cell count, so... $346.trevc2 said:It looks great, very clean. What would be the ballpark costs for laser cutting tabs to accommodate something like a 20s14p (single rows of 14) pack?
auraslip said:Is it possible to work out a solution that doesn't require welding or soldering the cells? Some sort of spring system?
The reason why I ask is... well, used 18650 cells are basically free if you know where to look. If there was a system that allowed you to easily swap out bad cells, building a pack out of recycled cells would be a cinch. 18650 cells are ubiquitous around the world. If there was an easy system to turn used 18650 cells into ebike battery packs, this rich man's hobby might suddenly become viable for everyone with a bit of spare time and a little bit of knowledge.
The "basically free" cells won't be capable of any meaningful output power in the numbers we're fitting on a bike, unless you're running a 250w system![]()
auraslip said:The "basically free" cells won't be capable of any meaningful output power in the numbers we're fitting on a bike, unless you're running a 250w system![]()
tell that to doc and all his happy customers![]()
Anything is *possible*. However I there already are at least couple solutions on ES, also I am targeting more professional users. Digging around in laptop junk, disassembling old batteries, testing each cell an then replacing them one by one each month is just not an option for them.auraslip said:Is it possible to work out a solution that doesn't require welding or soldering the cells? Some sort of spring system?
circuit said:Guys... Check this out!!
Guess what that is... Yup, that's a pure awesomeness!! As you can see, fuse design is different. I had to do that to lower manufacturing cost. Still good enough, I think.
OK, not ideal, just first batch... Some details still need improving from my and manufacturer's side. Price, for example. I was quoted big and, after delivery, bill turned out to be twice bigger. Bummer, quite large investment already.
Anyway, this first batch is good enough to assemble first prototypes. As you can see, these are for 8p packs. So: 8p, 6p and 4p configurations are available. These are designed for spot welding, but are soldering-friendly as well.
I have also improved plastic tray's design to bring cost a little lower. Looks the same. So double yay!
All what remains now is to order some paper spacers. Will do that shortly, probably will be in my hands in one week.
So... Is it time to start a selling thread? Or would you like to see my own pack being assemble first?![]()
Did not check current handling of current batch yet. Should be around 7A/cell (2.5C for most cells).ecruz said:At what amperage would they break connection?
With some additional hand work - possible.ecruz said:We can put them together for larger parallel packs no?
If we are talking about 22s10p pack, multiplied by 5... You know, that looks possible. Quantity maybe not enough to make any money, but really possible to do.ecruz said:Well, I am making and most people I am working with high power packs. 22s10p of 18650 cells, the packs will be hitting about 70amps max so 8 amps per cell, so this will not work. At least 5 of us would want a 10amp per cell fuse, so do not know if that is a hassle from a manufacturing point. I do see a market for these as it makes total sense but different gauges would be a reality. Maybe for now you might want to stay with in the most popular gauge and as business grows offer different gauges. Just giving you feedback. I would be a customer with the right product for me if that helps.
circuit said:If we are talking about 22s10p pack, multiplied by 5... You know, that looks possible. Quantity maybe not enough to make any money, but really possible to do.ecruz said:Well, I am making and most people I am working with high power packs. 22s10p of 18650 cells, the packs will be hitting about 70amps max so 8 amps per cell, so this will not work. At least 5 of us would want a 10amp per cell fuse, so do not know if that is a hassle from a manufacturing point. I do see a market for these as it makes total sense but different gauges would be a reality. Maybe for now you might want to stay with in the most popular gauge and as business grows offer different gauges. Just giving you feedback. I would be a customer with the right product for me if that helps.
Higher current rating is also possible. Maybe not tomorrow, but after 6-8 weeks. Can you wait so long?
Thanks for this review. Unfortunately such welder only covers a "buy a spot welder" part, but not "design and build a suitable head for it". I mean, that welder is okay to weld 2 or 3 cells together, but when it comes to large battery.. Hard to reach in to middle of pack, so external "mobile" head would be required. With replaceable tips, springs for pressure equalization, etc... It gets quite complex project to get good results.ecruz said:Check out this review I did on a spot welder $180 to your door from ebay.
http://youtu.be/3RfhTz_MP0A
So, you mean, everyone using your assembly kit should buy professional cell welder assembly bank?circuit said:Thanks for this review. Unfortunately such welder only covers a "buy a spot welder" part, but not "design and build a suitable head for it". I mean, that welder is okay to weld 2 or 3 cells together, but when it comes to large battery.. Hard to reach in to middle of pack, so external "mobile" head would be required. With replaceable tips, springs for pressure equalization, etc... It gets quite complex project to get good results.ecruz said:Check out this review I did on a spot welder $180 to your door from ebay.
I'm not saying it is not possible or very hard to do, for example existing arms could be extended ant that's it. Anyway this is just a minor issue against other two: shipping prices and shipping generally.
They are as close as possible already, touching each other, where safety allows. In some places there is a gap to prevent short circuit due to sleeve wear.Gab said:Whilst you are still early in the design phase, can you change the cell spacing to use the U type spacer where the battery cells sit vey close to each other like in the dewalt 18650 tool packs ?
Nope. Professional tools are not required for one-off project.parabellum said:So, you mean, everyone using your assembly kit should buy professional cell welder assembly bank?
