Hello. I'm buying a new battery for my ebike, and I want to experiment with charging it via a small (100-200w) solar panel (while I'm riding). The Genasun GVB-8, or less expensive boost MPPTs, claim to be able to boost the voltage from a small panel to charge a typical ebike battery. I am aware that it will be a slow charge, and an unweildy panel, but I have applications where I think it may be worth it (A roof on an e-trike for example). I want to use a lifePO4 battery for safety reasons.
My question is - what lithium packs, or specifically, what BMS, will work for this? They can't all be designed to be used in this way. They would be using the charge and discharge port simultaneously, which I don't believe is always possible, depending on the BMS, and certainly is not what they are designed for. I've seen some sellers specifically state not to do that. However, I know someone's figured it out, because you see these builds around. How can I find out what specific battery hardware or battery brands are available which will work for this? Thanks
