Discussion moved here:
endless-sphere.com
I know that an aluminium track frame is not the most suitable frame to turn into an ebike. I do have some other bikes, which are also all track frames
I have youtube channel https://www.youtube.com/@jetthepanda where I film my people riding around the city. Some of these people are abnormally fast freaks of nature, some are even pro's and even though I am actively training to get myself faster, I doubt I will ever be able to keep up with them when they are really pushing. So I've started looking into the idea of turning one of my bikes into an ebike. I am happy to do most of the work pedalling myself. I just need a little extra boost to help me sustain the higher speeds, which I think electricity would be perfect for. The speeds I'm having problems getting up to quickly and staying at are around 30mph and up, I can get there but not as quickly as the guys I'm following and I can't maintain it long enough to stay on the guys I'm filming.
I want to keep the bike looking as stealthy non ebike as possible. I was originally thinking rear hub with a bottle battery. I found these hubs with controller and torque sensor built into the hub, all you need to do is plug a water bottle battery in.
www.100g.tech
I contacted both of them and they do not provide their hubs for 120mm drop out spacing. I wouldn't be adverse to grinding the axle down myself. I build all my own bikes and wheels, I think I'm pretty handy when it comes to this kind of stuff.
Does anyone know of a similar rear hub that would fit into 120mm dropouts? Or do you know if it's hard to modify one of the above hubs to fit?
I then came across these friction drives, which I think are very interesting. I wouldn't need to modify anything, all I'd need to do is bolt the motor on. I could even take it off when I didn't need it.
qirollshop.com
I am considering the Aliexpress friction drive because that, plus a water bottle battery enclosure, some batteries and a BMS seems to be the most economical route. I think it would be more powerful than the cheapest qiroll kit too QR-E MUTE +B60 Battery Kit I think the motor of the qiroll looks nice, but the battery and throttle button look terribly designed. I would much rather have a stealthy water bottle that actually looked like a water bottle.
What are your thoughts? Does anyone have experience with the Aliexpress friction motor? What BMS do you recommend for a small DIY water bottle battery? Will I be "spinning out" with these lower powered motors at the speeds that I want to go at or will they still be helping me along?
I do have a fork that can take a disc brake and I would use that fork with a disc brake if I went electric. I Would also mount a rear brake and change the fixed cog to a freewheel.
Help me choose a motor / battery set up :)
This is the bike I want to convert, I know it's not ideal but I would prefer not to have to buy another bike and I have my heart set on using this one. It was my first proper bike, I now have other nicer bikes than it but I still want to use the frame for something. I know someone will come...
endless-sphere.com
Geeko Rear - Ebike Kit - 100g.tech
Geeko-Rear: A Cyclist's Dream Come True! Whether for daily urban rides, epic long-distance treks, or tough mountain biking, it's your perfect companion.
www.100g.tech
QIROLL - Transform Any Bicycle with Our Lightweight Friction Drive Motor.
Qiroll is the smallest and lightest portable Electric bike conversion kit with battery and super easy installation , a stealthy friction-drive system that is highly efficient. By carrying two sets batteries weighing a total of 2kg, you can achieve a cruising range of nearly 142km. Each H70...
qirollshop.com
