I'm converting an old lawnmower from gas to electric. Made tremendous progress, but on Monday I received my batteries and BMS and fear caused progress to grind to a halt...
Here is a pic of my monster:
View attachment bluemonster.pdf
The battery pack is 48v 100ah comprised of 16 individual 3.7v 100ah packs. Here is a pic of one of the battery packs:
View attachment IMG_2015.pdf
The BMS is a 16S100A
Below is the diagram that was provided with the BMS:
View attachment 48V BMS connecting drawing.pdf
The diagram shows the B- and P-/Output- (on the right and left side, but no wires, just holes in the circuit board), and all the connections to the battery terminals (B-, B1+, B2+, B3+, ..., B16+/Output+)
I really appreciate any help in answering the following questions:
1) I understand that all the "pig-tails" that will connect at the bottom of the BMS will connect to the appropriate battery terminals (as is detailed in the diagram). Are these the only wires that will connect to the battery pack?
2) What should be connected to the B- and P-/Output- on the BMS (left and right side)?
3) I need to buy a charger for this battery pack, and would appreciate any recommendations. Since it's a lawnmower for personal use, it does not need to charge quickly (days would be fine).
4) Where do I connect the charger (e.g. directly to the battery or BMS)?
