LewTwo
This may fall under "everyone already knew that" and if so then some one tell me and I will delete this thread.
I am moving the battery from the front of my bike to the back. I already have 7 feet of 14 gauge copper, silicon ruber insulated battery cable on hand but my question was "is this sufficiently large or should I order some 10 gauge cable"? So I began trolling the internet looking for answers and found this page:
https://www.altestore.com/howto/wire-sizing-tool-for-12-24-and-48-volt-dc-systems-a106/
It seemed to have the information I was looking for but I wanted to know what the difference between cable sizes was and more importantly how much switching cable size would affect the real world outcome ... or at least a guestimate. So I put together a spreadsheet to compare cable size with specific battery parameters. Lastly it calculates the difference in speed due to cable loss (if I got all the formulas correct).
One can change the input parameters (yellow cells) for a given battery and controler to determine the voltage loss across a specific distance. Add the nominal rated speed for those power parameters gives the real world speed loss as well. In this case I am looking at moving the battery about 4 cable feet (max) for my 15 Amp Controller and 36 Volt 350 watt motor. That is going to cost me 0.334 MPH. Using a 12 gauge cable would only recover 0.124 MPH or 7.5 watts. I think that I will use the 14 gauge cable I have on hand.
Comments, corrections and criticisms welcomed.View attachment Power Cable Loss.xls
