Battery cells safety when building
Cyclomania
Northern Europe
Hi
So I am going to build my first battery soon.
What are the scenarios that could make a cell go off and explode or burn? And how do I best avoid this?
Also, I've read that they mostly start big fires if they go off. Or will they also explode at times?
Any help on how to avoid this is much appreciated.
What are the critical stages during the build?
Start here:
and work your way thru the rest of the battery forum as far as you can. More information is better for your intent; it is likely to take you some long hours of reading up on battery building before you should start buying or doing anything, to do this safely.
The reason I recommend you read the forum rather than us re-posting everything here is that it would take several books' worth of posts to convey all of this information, and it is already posted in other threads. ;)
