gmatht
10 µW
- Joined
- Sep 8, 2015
- Messages
- 5
My battery is charged (it is sitting at 28V and is a 24V battery), but there is no power the the bike electronics, except when the charger is plugged in. What can cause this? In what situations is the Signalab BMSs designed to cut power to the load?
Some context:
There is 28V going into my Signalab SH-S E321748 but essentially nothing coming out. Most of the cells are at 3.4V, but one is at 3.5V.
The bike has worked before. It had a problem with the anderson connectors leading to the motor. This meant that the throttle did nothing. I fixed the anderson connectors, and then it worked for a while. The bike was rained on a little, it still worked, but I disconnected the electronics and let it dry for a couple of days before I charged it. It seemed to charge fine. Most of the electronics worked (e.g. the cycle computer at the front), however again the throttle didn't work. I fiddled around with reconnecting various connections to the motor. During the fiddling the bike fell over. I don't know when exactly this happened, but the bike computer stopped showing anything. I don't see any obvious corrosion anywhere.
The battery seems to be fine. It is sitting at 28V, which is pretty high, usually it sat around 26.6V when the motor was off. I would suspect that if the battery was simple dead, the voltage would drop, perhaps below 24V on load. However, the battery stays at 28V and only the "load" voltage coming out of the BMS drops. Also the battery was fine a couple of days ago, so I would have though the battery would die.
The Signalab BMS doesn't seem to be drawing any power from the battery.
If I attach the charger the electronics comes on, and throttle moves the wheel somewhat.
It sounds to me like the BMS is dead, but I don't have a manual so I am not sure if it might be cutting power because of a fault elsewhere.
Some context:
