battery charger repair
jocoman
1 W
Maybe i'm wasting my time here but....
My 48v charger blew up. My compressor started up while I was charging and the charger smoked.
Here is a pic of the damage. The replacement pieces are easy to source.
Problem is I'm working without a schematic and I can't identify the resistor values.
Here is a pic.
It is a model EP6004JL for what its worth.
Your help and comments wouild be great and appreciated.
txs
You can use a resistor color code chart to try and identify the values of resistors that you have there: http://www.diyaudioandvideo.com/Electronics/ResistorColorCodes/ResistorColorCode.gif
Then you can double-check the values with a multi meter to see if they are bad or not.
Also looks like those mosfets may have gone bad.
