Battery for Bafang Max Drive: needs comms cable?
balachai
New here
I'm about to buy an ebike with a Bafang Max Drive motor. One of the features I'm looking for is an "open" system to maximise my choice of replacement batteries in the future.
However, it seems the Max Drive requires batteries to connect a 4-wire communication cable, as well as the positive and negative power connections. I guess this is so the battery's BMS can instruct the Max Drive to reduce the discharge power when the battery's not feeling good :)
What kind of batteries are compatible with the Max Drive? If you plugged in a battery without the comms cable, would it work at all? If I want an "open" system, should I be looking at a bike with the Bafang BBS01B instead?
The cable connector can be seen in pages 21 & 25 in the Max Drive Dealer manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiAqfSzsobuAhXjzjgGHcO9Bv8QFjAAegQIAxAC&url=https%3A%2F%2Fboxbike.dk%2Fimg%2Fcms%2FMAX%25C2%25A0DRIVE%25C2%25A0SYSTEM%25C2%25A0DEALER%25C2%25A0MANUAL-2-3.pdf&usg=AOvVaw12gl47LJ2wl-jun-9U8nFq
I have a CTM bike with M400 motor, DPC18C display. As you can see below pictures dont have comm cable only positive and negative. It works:
Wow thanks, that's great information! :) Looks like a replacement battery can simply connect with positive and negative.
