Step 1. pick a prepopulated cell or module from the drop down or enter your own cell on the cell data sheet and it will appear in the drop down on the calculator sheet
Step 2. pick desired voltage from the range provided in the drop down
step 3. pick desired Ah from the range provided in the drop down
Any time a new cell or module is chosen you must update the voltage and Ah hours again from the drop down menus (the numbers have to match the capabilities of the cell you pick). Formula cells are protected. Feedback appreciated.
https://docs.google.com/spreadsheets/d/1ic-Np5yBlkwlCYTlfI4uL6GHjArwZwtJqDRthrTotCM/edit?usp=sharing
