dnmun said:
really nice/well built/effective layout, you did good on this one too.
did you decide to go with this BMS because it was designed to 10S?
will you do something to hack the shunt to see if you can raise the output current limits?
i am gonna buy some of the 15S D126 to build up some 15S hobbyking packs and was already thinking of how to hack the shunt by soldering another layer of shunt resistors on top of those to double the output power. if the mosfets won't handle it, i will upgrade them too.
if you connect those two sections in series, i would recommend that you make the connection between the two packs a soldered connection so it cannot be physically separated by accident. when the connection goes open while the BMS is connected, then the channel above the break, which would be #6 for you, will burn out the shunt transistor and it will then drain down that cell.
i like the BMS choice though because it is using a digital processor for the controls so it should be much more reliable and the gate voltages on the mosfets would be full voltage so the mosfets won't have issues with partial turn on associated with some other designs.
i may end up with some extra JST-XH connectors if you need them to keep the ability to balance charge it with the 168 or icharger. maybe there is someone close by you too who is scrappping a 5-6S turnigy and they could cut the leads off for you too.
Thanks. The pack is not finished yet. i am thinking of using some fiber reinforced board to put on sides, bottom and top then heatshrinking in a tube.
There was nothing in particular about that BMS. It was 15A constant, small, 10S, that's all i needed
i need to keep them separate as my scooter design requires it to be that way for wire routing. Im not intending plugging it off at all as there is on board charger.
I probably wont increase power as these panasonic cells ar 1C at best and i dont want to push them too hard, after all this will be run about scooter for someone.
I tried it few days ago and 350W 12" hub is nippy, so i am good with that.
For the JST, i have few pigtails made with them, with connectors i use on my A123 kits, they are bigger and has clips, secure.
All in all i am not that good in electronics so swapping something like fets would be job and a half for me
The cycle life is a draw back for me on these cells. otherwise, say in automobile situation they would be great - 270V 100AH pack would weigh 120kg + assembly. Wicked
