agniusm
The charger was dissassembled and all big components secured with silicone.
agniusm said:Here it goes again. Fu*k, fu*k, fu*k, what the fu*k is wrong with those Chinese? Bought 56 NCR18650B cells, got 48 + fu*k knows what others. Second purchase with them second fu*k up. Fu*k
This is bad even before i start testing them, might be dry or something else like 20AH A123 i got from them. Fu*k..
agniusm said:No, i am talking with them at the moment to send me out 8 Panasonic cells, if they will agree all is bad but not totally fuc*ked. Those grey ones are LG 2000mah cells so even if i was dumb enough to mix them i wouldn't because capacity.
agniusm said:OK, got it all tested. Dont know about checking the gate if its fully open but from negative to left leg returns 9V with or without load. There are 8 mosfets and 4 on the same side as damaged one do not work returning 0V. My assumption is that 20A (4x5A a mosfet) is top limit.
I have attached the brake and was simulating load to check draw, and max it was sucking was 24A.
I suppose this was what caused it to burn out.
i have a vid, will add it when its uploaded...
i think i will order a bigger one from Henry, the 35A one HCX-D100: http://bestechpower.com/37v10spcmbmspcbforli-ionli-polymerbatterypack/PCM-D100.html
The balancing function did work properly as it balanced the pack within .00.
agniusm said:I would change the cell I have used. Althou weight of that cell is best higher count of P is required. They are best at .2C .5C is the limit for them in my opinion. With your 30AH pack max draw must be limited to 15A at best.
ecruz said:I am hoping to get 68a continues if needed
New batteries behave nice, give em 50 cycles in described conditions and real world catches you up. Let space for parallel Nanotech string 3-5Ah and enjoy until capacity sucks, due to degradation.ecruz said:Have you seen this video? http://www.youtube.com/watch?v=_UxIwS0EimE
parabellum said:ecruz said:I am hoping to get 68a continues if neededNew batteries behave nice, give em 50 cycles in described conditions and real world catches you up. Let space for parallel Nanotech string 3-5Ah and enjoy until capacity sucks, due to degradation.ecruz said:Have you seen this video? http://www.youtube.com/watch?v=_UxIwS0EimE![]()
ecruz said:agniusm said:I would change the cell I have used. Althou weight of that cell is best higher count of P is required. They are best at .2C .5C is the limit for them in my opinion. With your 30AH pack max draw must be limited to 15A at best.
Scratching my head, I am seeing plenty of test in ecig forums and RC forums that they are 2c 6.8a You are scaring me lol I just ordered 220 of them as I was able to fit very comfortably 22s10p in the Torque Raptor to use with a Cromotor v3. I am hoping to get good torque and over 50mph bursts. I am hoping to get 68a continues if needed. Am I dreaming did I put a decimal point wrong somewhere? LOL
Sigmacom said:I've used these in my new Bomber battery. It's a very large pack at 16S14P - sounds like yours is about the same number of cells - what is your config?
Mine provides 50A no problem. I haven't pushed it to 60A but I doubt there would be any issue (but that's with 14P). What you do have to be very careful of is charge rate. Don't charge them at more than 0.3C or you will drastically lower their capacity. I actually charge mine slower than that with a UNA9 balance charger at only 0.6A per cell. I'll get around to posting a build thread soon.
Sigmacom said:ecruz said:agniusm said:I would change the cell I have used. Althou weight of that cell is best higher count of P is required. They are best at .2C .5C is the limit for them in my opinion. With your 30AH pack max draw must be limited to 15A at best.
