liared
I have ordered and received a 24 Volt 20 AH LiFePo4 battery from battery supplier Sun-Thing – see left image above.
It puzzels me is that the same contact (wiring) is used for both charging and e-bike motor load. I have earlier bought 24 and 36 Volt 20 AH LiFePo4 batteries from Li Ping and Sun-Thing and all of these batteries have had separate wirings for charge and load.
There is no way of seeing the BMS or sense wires of the 24 Volt battery unless I open up the battery.
Sun-Thing says by mail that the one and only wiring for both charging/BMS and load is OK (“it is include the bms .”)
Is there someone here in the EndlessSphere forum that uses this same “one/same contact only” for both charge and load and can confirm that it works fine with the BMS!?
