OCD Garage
I've got a 48 volt 20Ah 'duct tape' style battery from CDI. Every now and then my system shuts down completely, I disconnect, then reconnect the positive lead and the bike goes again. Last time this happened my BMS was at fault and I replaced it with exactly the same factory one from CDI. This time I'd like to install a heavy duty 50amp model I bought from Ping but the connectors for the circuit board are different. Do I need to solder the new connections directly onto the battery tabs? Does it matter if they go in exactly the same spot as the originals? Inside my pack looks like two banks of cells glued together with some of the BMS wires going in the middle, do I need to split these apart or can I splice the BMS wires onto the originals?
