Hi Guys,
I recently purchased a 36V 10.4 AH battery from Facebook marketplace, it looks like new, very well made I should say, the seller said he lost his ZDZA brand ebike, therefore he has to sell this battery.
It has a "soft" micro touch switch, I assume it is on / off? The discharge port has 5 pins, with +, and - on the outside, and 3 pins in the middle are labeled as 1, 2, and 3, the whole 5 pin layout is: + 1 2 3 -.
If I connect my multi-meter probes to these pins, such as: red probe to + pin, black to the - pin, I read no voltage. However, if I connect the black meter prob to 2 or 3, I read 36V and 42V, pin 1 also reads no voltage. Pressing the On/Off switch (either short or long press) does not change these voltage readings.
I took off the "lid / end cap" on the side on which the discharge port is installed, and I discovered: there are 2 thick gauge wires (red/black) that are connected to + and - pins, I think these are the power wires that can carry high load.
There are also 2 thin wires (signal wire's gauge, definitely not load bearing) that are connected to the pin 2 and 3, pin 1 is not connected. All these wires are heavily glued/siliconed from within the battery case, so I did not disassemble further.
The micro touch On/Off switch is installed on the other side of the battery case opposite to the discharge port. I took this end cap off as well, and found the on/off switch is install in a small PCB with a number of electronic components, this PCB board is connected with 2 small signal wires (red/black) into the battery body. I cannot measure any voltage across these 2 wires.
So my questions are:
1. Is the On/Off used to turn ON and OFF the battery?
2. I suspect pin 2 and 3 on the discharge port have some functionality/usage to turn on the negative pin. Maybe they are connected to the controller or maybe the LCD screen, where the bike user can select some functions from the LCD screen, and that action in turn will turn the voltage to the negative pin?
3. Since my bike is not ZDZA, so I only need the battery to output 36V, is there a way to somehow do this? Maybe by sending some sort of signal to pin 2 or pin 3? I did not dare to short these 2 pins, yet.
Or maybe the battery is just dead.
Any suggestions?
Thanks
Hex
Any suggestions?
Thanks
Hex
