Bayliner Conversion
got it printing looks like it needs some tweaking figure that out tomorrow
playing around with cura, was trying to stack the pieces but they just mash together
have to see if i can stack them in freecad, be nice to know what they call that function
all the parts are 0.2mm-0.3mm smaller than designed
make the changes tomorrow and try again
think its because i had to double circle to punch out the center
and i missed it
Looking good!
You're further along with CAD than I am. Other that the stuff on thingiverse I'm only doing brackets and boxes so far.
What kind of filament are you going to use for that coupling? I just ordered a filament dryer but haven't decided on which CF/nylon filament to buy. It'll probably be Nylon X from Matterhackers @$58/½kilo.
You're aluminum works good and strong.
earlier in this thread theres a youtube video of a guy printing carbon fiber on his ender, probably that filament.
having issues with cura, have to uninstall and install to open it then it wont upload this new file to print, it did yesterday but not today :? trying to figure out what the heck is going on might try a different company. its another snoopy company that wants all your info and access to everything in your computer
these are FC std files
***figured it out, had to mesh it, if you dont mesh it doesnt convert, i didnt mesh/convert yesterday, i dont know whats going on there but from their wiki, if you dont mesh, holes print smaller
i just made them bigger :shock:
Quoted from FreeCAD
Which Method to choose ?
Method 2 is to be preferred. Among the reasons:
When you have more than one Body to convert you can use Tools from Workbench Mesh.svg Mesh Workbench. For example, you can fuse meshes before exporting.
Curved surfaces are represented in STL as a series of straight-line segments, generated via tessellation. This results in slightly under-sized inside dimensions for curved surfaces. If you are exporting to use in 3D-printing, this may result in an under-sized hole, for example. In such cases you may need a finer tessellation value. When exporting from another workbench using File → Export..., the tessellation is controlled by the overall display tessellation set in Edit → Preferences... → Part Design → Shape view. However, because those parameters control the tessellation used to render shapes on the display, decreasing them will slow down display rendering, often significantly. In addition, exporting immediately after changing the display tessellation preference value will not have the desired effect because display tessellation is not updated immediately. One must force a change in the underlying model to cause the tessellation to be recomputed -- for example, by editing a sketch parameter (Setting it to its original value will suffice).
itll suck if my bigger holes get small again. find out in 4.5hrs
I couldn't find it, but then I miss stuff. :oops:
It might work OK out of ABS but I hear it's about as hard to print as CF or fiberglass nylon.
I'm new at this but I think I'd print that coupling laying down (with supports enabled) to take advantage of layer adhesion. Pretty sure it would snap in half if printed standing up. Kind of like paying atension to the grain when working with wood. Probably have to clean some strings out of the hole too.
was thinking about that if i was to stack print 3 files there would be 2 weak spots
then thought the infill pattern might take care of that if its all a 1 piece design
sain smart carbon fiber
https://www.youtube.com/watch?v=LqhcmCrlx8o
coupling v2
need a v3 and itll be done
pretty snug, had to tap it on by hand
brass insert is perfect on the 3 tabs but the hole for the body is a little big
cut that extra brass off thats protruding
ill use this for testing though
back to fabricating :thumb:
drilled out the upper 2x2s in order to get a socket on the pan bolts
the motor is sitting 1/4 inch too high
while printing the coupling theres a middle section for the set screw that fastens the coupling to the motor shaft, its supposed to be 5mm thick
for some reason its 10mm thick :evil:
only need 3.3mm for the countersink screw head
designed the new V3 coupling but i cant attach the file to this post :?:
take 5 hrs to print and cant fabricate til its done
time to design the motor adapter plate, i still have a couple photocopies from earlier
ender3 has a 220mm build plate
problem,
im 222mm on the motor plate
solution
the da85 has another set of motor mount holes slightly inward :thumb:
Looks good!
I've got the parameters in Cura set at 230x230 for my E3.
If it breaks, try printing it laying down. However It might be just fine as it is as you made it nice and fat.
That Sainsmart CF filament gets pretty good reviews and has an attractive price (½ of NylonX). Ordered a roll today. Thanx for the tip.
had 2 failed prints, first came unstuck after 2 hours
tried hairspray, 2 hrs later it came unstuck
then tried gluestick and a raft
3rd came out perfect :thumb:
it spins dead nutz true on the shaft :thumb:
now i can mount the motor :D
lots of room
shifting linkage is hitting the 2x2
will be using these other bolt holes for 3d printed adapter plate
so if you spin the motor a few degrees clockwise itll square off the bolt pattern to center and give the shifting linkage clearance required
wasnt that bad to do
got the clearance
going to mount the controller like this
need to go find some countersunk m8x30 bolts to bolt the motor to the plate
PLA
cant find countersunk m8 1.25 25mm bolts anywhere local
ordered them from amazon, get them tomorrow but theyre too long, 55mm
the 25mm had to wait til sunday for delivery
pulled the impeller
controller has 12v 10a or 15a coming out of it.
those impellers arent very efficient
either use a fan or electric pump
time to try and get the electrical figured out and find out where to get the app from
bought jumper cables from amazon with andersons on them, theyre not tinned copper but itll get it going
https://www.amazon.ca/Booster-Jumper-Cables-Connect-Travel/dp/B08GK7YBMS/ref=sr_1_11?dchild=1&keywords=anderson+jumper+cables&qid=1631064353&sr=8-11
Denzel has a youtube for the da90, my phase arent labelled like that one but ill connect it in the same order
https://www.youtube.com/watch?v=AbbhCIfkSOQ
connected Blue to U
Green to V
Yellow to W
time stamped
https://youtu.be/AbbhCIfkSOQ?t=206
that didnt work, try throttle, on/off, forward/rev, nothing but a
loooooooooooooooooong steady beep from controller
going to swap B and Y
still beeeeeep
disconnect throttle jst
beeeeeeeeeeeep stopped
the red and white wires from throttle were hanging out loose when it arrived so i just put them where i thought they should be
put phases back and will swap throttle wires
that fixed the throttle but phase was wrong
motor shuttered and jumped 2 inches :shock:
swapped phase :thumb:
plugged controller into laptop
no driver available???????
ill email Alex at east gem
kit comes with an alarm and wireless power key
unplugged keyed switch and plugged in alarm
had a blue wire with a jst pin hanging loose
plugged it in the jst and get nothing
woder if i need to wire the keyed switch to these 2 left over wires from alarm?
picture of the coupling at 2000?rpm
designed V1 controller mounting bracket
should be able to mount the fan, dc/dc converter,for/rev, hi/low then all i need to bring out is
throttle
battery
com cable
will take 46.5hrs to print :D
had the motor running at 2000? rpm for 4hrs today(no load) temp was a steady 103f/ 40 celsius
Alex sent me the files for the driver
theyre RAR files
used the windows app store to get their RAR opener
it doesnt work :?
anyone know a good RAR opener so i dont have to keep downloading RAR openers?
wound up pulling the pan and running m8 ready rod up where it was possible
m8 countersunk motor bolts
bolted up pretty snuggly
hope the alignment is still good
controller plate is coming along
just need to get that app for testing
