At the Bafang harness side of the throttle input going to the motor, I still read +5V between the two lower pins adjacent to the notch on the female connector. This tells me the +5V bias supply from the controller to the hall effect throttle isn't blown. When I disconnect the throttle cable and power the hall effect throttle with a separate +5V supply and look at the signal output, I see from 1.1V to ~4.2V as I turn the throttle from home to full throttle. This is what I'd expect... I even tried shorting +5V to the throttle signal directly on the harness side of the throttle input going to the motor to force a full throttle condition and still nothing happens.
Has anyone else ever had a case where the throttle designated assist flash setting became corrupted to '0'? It's the only thing left I can think of that would cause the throttle not to work anymore?
BTW, I'm using the EMPowered .el file btw... Everything worked fine when I first downloaded the file to the Bafang controller...
Thanks to anyone who can provide some input!
Charlie
Charlie
