RVD
I am thinking of building a new battery pack for my BBS02 750w. It is currently set for 48v which all I think means that it has a LVC set for 41v. I can look into changing this or I don't care...I always monitor my own voltage usage with a watt meter on my bike anyway.
I am currently using lipo and running it at 12s1p (44v 5ah). I have a relatively short 8 mile commute and this pack is able to handle each way very easily (I usually end up using about 2.5-3ah worth of battery). I charge at work using a very slow charger. i use an imax b6ac which is only 50 watts so it takes around 4 hours or so to charge up this pack at work but I am not in any rush and I want it to be safe (don't want a fire at work in the bike cage).
For my 18650 pack I am using Sony US18650V3 cells. I believe that these are lithium manganese cells and each cell is 2150-2250ah. I am thinking of building a 14s3p pack so it will be a 52v pack but probably closer to 58v or so hot off the charger.
At 25 amp, this would be pushing a peak of 1450 watts. I am assuming that my motor will not like this for any sustained period of time but my commute mostly flat and downhill with the only exception of one very big monster hill at the end of my commute when I am coming home. So even if I start out at a high voltage, by the time I am near home on this big hill (>20% grade), I'm guessing I'll be at around 52v so 1300 watts and will be at that max wattage for maybe around 5 minutes.
On my smaller 44v lipo setup, the motor seems to handle 1100 watts (with me pedaling) going up that big hill just fine. Anyone know if it can handle 1300 watts ok?
I have not done any modifications to my BBS02. I bought it from luna late last year so I'm not sure if it has the updated controller mosfets or not.
