BBS02 Hall fault with complications Grin stuff
boabywomack
Hiya, hooked up phaserunner CA3 to bafang, dynamic autotune shows hall 3 fault or grounded. Can't clear or use sensored operation. No pas signal. Connectors good. Reverted to stock, showing er 8 halls. No assist. Before messing appeared to work ok. Don't think I've damaged while swapping to PR. Any ideas great knowledge base?
Thanks
IF the halls worked before changing things, and don't now, the most likely problem is a broken wire or connector contact.
ESD damage to a hall sensor is also possible.
