The motor worked again good for some time
then the problems start again
the motor stopped working
disconnect power, start up and worked again
the I go for one large trip 100km
I open throttle motor work, when I close throttle, when I open again motor do nothing
then suddenly the motor work again
that happend a number of times
when I open the throttle open for some time, I see on screen that the power changed from full and fall to half
and again full, when the motor has warmed up it worked flawlessly
on destination I see when I start up, the motor stopped
then worked again.
after cooling the motor, I want to start up again
the motor stopped, start up again this after a number of times, the motor stopped compleet
I see on screen sometimes controller error 30H than sometimes 4H
the battery full are giving on screen empty and switch again to full
all nonsens on screen sometimes 91km/h then 0
Next day, I startup, nothing happend on screen
I connect another screen I see error 8H hall sensor
This is the second hall sensor I renew.
But when I start up after renewing the hall sensor, the screen stays black
So I think the controller is again faulty
This is mine 4the controller for the bafang BBS02
enough :x
I give the BBS02 15S, load max 61.5V, mayby therefore the controller fail after time
Therefore I want to change the bafang controller to an phaserunner controller
Then I can load battery to 63V and give 25A
The controllers from bafang are the weakest link from the BBS02 engine
there are two connections on the controller do I need to connect both?
the white and the black?
I do not use PAS Pedal Assistant Sensor grey cable from Hall sensor is not connect
Suggestion why screen stays black
