For my first e-bike build I chose a Yuba Mundo cargo bike. I purchased a frameset and 750 watt BBS02 mid-drive from Dan at Ichi Bikes. The first step was to grind off the cantilever posts front and back since I was going to be running disc brakes. Yuba uses 14mm dropouts with bmx hubs. After seeing Sam's (mechanic at Ichi) Mundo modified to use a thru axle I decided to go that route. I made some adapters and had Sam weld them in place for me. A mid drive paired with a thru axle is a good combo since you don't have to worry about the axle getting pulled out of alignment.
Next was the battery pack build. Since I had never built one before, I decided to go with Headway cells since they could be bolted together.
I built a 2P16S pack with the cells in two sections so that I could put 16 cells on each side of the bike, then I made some wooden frames to put the cells in and enclosed them with a sheet of plexiglass on each side. I put the bms in a project box mounted behind the seat tube.
I decided to integrate the headlight, tail light, and horn with handlebar controls and power it all off of the main pack using a DC to DC converter. So the project box also contains fuse panels, relays, and a dimmer for the headlight so that I can have high / low beam. On the cover side of the box is a switch for the amp and a keyed switch tied into the brake cut off circuit. On the seat tube side of the box is an anderson powerpole connector for charging the battery.
I mounted the atv led headlight to a secondary handlebar stem.
After a couple of rides I decided that all I was missing was some tunes. So, I put a pair of 4" speakers in a pvc enclosure up front and mounted a little bluetooth amp for it on top of the project box next to the DC to DC converter.
Since I decided to keep this project a street legal build and have a 20 mph max assisted speed I replaced the 48 tooth chainring with a 38 tooth using an adapter from California E-Bike.
I'm using a sram x4 shifter so that I can run a 6/7/8-speed chain instead of a narrower 9 or 10 speed chain and I put a 7-speed cassette on with a spacer against the wheel.
On top of the rear deck is an axle holder for towing another bike. I can actually sag another bike rider and their bike with this setup. The bike is a blast to ride and my daughter has plenty of room on the back even with the bags on it.
