kiltedcelt
⚡ Regular
So, I've got a BBSHD and in the past I've used it on a cargo bike along with an Alfine 8 speed hub, and NO shift sensor. I learned early on with Alfine hubs that you pause when shifting and I found that the momentary pause before shifting was enough to cut off the BBSHD anyway, so no shift sensor necessary. I might've been playing with fire as there is always the possibility that some instance might occur where I shifted while the motor was powered. However, in the year or so that I ran that cargo bike, I never did that. Now I riding tadpole trikes exclusively and I'm building up a trike to be my daily commuter/cargo hauler/all-rounder and this trike has my Rohloff hub in the rear and will get the BBSHD. Since the Rohloff utilizes brake cable housing for it's shifter, that kind of precludes using a traditional shift sensor since the housing won't fit into the ends of the sensor anyway. I've read in the past about folks using a brake cable sensor instead and using a momentary button that you press to manually kill the motor output before you shift. Probably not quite as seamless as the sensor which registers the cable movement, but probably adequate.
Let me add one other bit of information first though. The Rohloff I bought was just a basic unit, and at some point when I was ordering the Rohloff-specific spokes to lace it into a new wheel. I got the spokes from Peter White Cycles, one of only two Rohloff service dealers in the US, and when we were talking about my use of the hub Peter pointed out that since I was using in a tandem at the time, and intended to use it with e-assist, I needed to upgrade the internal sheer pins. Turns out I'd not purchased a tandem/e-bike specific Rohloff, but just a regular one. I sent the hub to Peter and his Rohloff tech upgraded the sheer pins to the steel (aluminum?), ones that are standard in the tandem/e-bike specific Rohloff hubs. These pins apparently resist greater torque forces imparted by tandem riders as well as the input from a mid-drive motor, or both.
Anyway, so my Rohloff is basically e-bike specific, but I've not found good solid information on exactly how I SHOULD handle the shifts with BBSHD+Rohloff. Is my practice of ceasing pedaling while shifting adequate enough, or should I be installing an actual cutoff that uses a momentary button? I guess the latter would be installed on one side and I would press it as I stopped pedaling and shift then release. Seems like it would work, but again - just not as well as a shift sensor, and part of me wonders if just stopping pedaling is effective enough. The only issue is when you stop pedaling on a regular chainring/crankset, you're effectively arresting the motion of the chain right then. If you stop pedaling a BBSHD, the chainring/chain can still move a few revolutions from inertia before stopping altogether. I don't know if the shift was occurring while the chain was spinning down if that would cause any issues or not. I suspect even a shift sensor works the same way, and in that regard all you're really concerned about is not dumping power from a motor into an internally geared hub while shifting.
I suspect the spinning-down chain imparts only negligible force into the hub if you're shifting at the same time. Worst case scenario, if shifted under load, I believe the Rohloff defaults into gear 7 as a protection measure then as soon as you left off the pressure on the chain/pedals then the hub will go into the gear it was being shifted into at the time. Worst, WORST case scenario is somehow you engage the sheer pins and those SHEER as their name says, preventing damage to the gears but necessitating sending the hub off for servicing. So, am I just overthinking this entire thing? I mean the Rohloff is a pricey hub and I don't want to trash it. Should I just buy a momentary switch with HIGO connector and utilize that in place of, or with a Y-splitter on the same line coming off the brake lever? For the record, the brake system is two hydraulic calipers controlled by one brake lever so I've got the basic brake cutoff that consists of a sensor and magnet that I have to rig up on the brake lever anyway. Only problem there would be a LONG extension/splitter since I'd want to run the button cutoff on the left handlebar and the Rohloff shifter/brake on the right. I have several extension cables but not sure if I have enough. Might need to buy more.
