Hi, My BBSHD with eggrider display works flawlessly for 15k km.
Today i switched my bike on.. had a "-" instead of a "0" on my eggrider display for speed, and "-" watt instead of "0"
I started the eggrider app, "error 30"
Checked all the cables but no luck.
Disconnected display, and connected my usb programming cable (as the non display trick, throttle should work at this moment, but no luck!..)
Then i found this post on reddit https://www.reddit.com/r/ebikes/comments/omu6mp/potentially_bricked_bbshd_controller_any_ideas/ And followed this instructions to flash my controller with this file:CRR10E4830E104001.1.hex
The error 30 was gone! and i was able to use my throttle again, but PAS is not working.
Disconnected the display, and connected my usb programming cable, and throttle worked, but no PAS..
It looks like my PAS is dead.
Now i'm a bit confused. Maybe i had a PAS error in the first place, and "fixed" the problem with re-flashing my controller?
Or maybe i had 2 problems at the same time, and fixed 1?
How does error 30 suddenly appear? i did not changed anything for months..
My controller MCU type is : STC15W4K56S4
I foundalso firmware bin's int this topic:https://endless-sphere.com/forums/viewtopic.php?f=28&t=100064 but those firmware versions give me a error, and i dont dare to flash these, too scared to brick my controller. "The file is over the validscope, and the exceeding parts has been cleared"
Some1 with a solution maybe? Thanks!
