Hello everyone.
so, to to quickly summarize : electric fat bike project in 48v.
not yet decided which engine to install (tsdz2 / bbshd / hubwheel) but the bbshd is still an option, but an expensive one so i have to measure twice, buy once.
the bike arrived recently, confirmation of the BB in 100mm and i wonder which version (width) of the bbshd buy for my frame.
and that's where you come in (I hope):
I have some measurements, photos and some points to clarify, if you could confirm me this:
so I made a paper template based on the measurements that I had found for the bbshd , taking a bit wide to be sure: a base of 130mm in diameter for the motor-case touching the frame bottom bracket.
obviously if I put that 130mm stuck to the bottom bracket, it touches the chainstay.
on the other hand if I distance 8 to 10mm from the BB, I have at least 3mm margin at chainstay.
no problem for 8 to 10mm spacer on the motor side?is it not too much ?
i know i will have to provide +/- the same spacing for the triangle mounting plate, with adequate bolts length.
and so the second interrogation:
from what I understood for the 68/100/120 version of the bafang in general and bbshd in particular, it is about the measure "internal" to which one must add 20mm of thread at the end, so 68 = 88 with thread, 100 = 120, 120 = 140.
Do you confirm that?
ok so for my frame and his 100mm bb, if I take a bbshd 100mm, including a washer-spacer 8 to 10mm, there would remain 10mm of screw on the left side to secure mounting:
is it enough? no particular concern to anticipate, including the pedal - frame space?
finally a photo of my current original chain line:
with the original front chainwheel that works slightly angled inwards to the big gear, I have about 1cm of spacing at the side of the tire.
if all goes well, as described above, I should go with the bafang to find myself pretty much in similar measures.
so for you is it all good, I can get started? or i missed something ?
thank you.
thank you.
