When tightening M6 bolts there is a 0.5-1 mm gap left between the steel bottom bracket and fixed holder. This will prevent the fixed holder to sit in parallel with the bottom bracket when tightening down the M33 locknut rendering some of the serrations unable to bite in to the bottom bracket.
Surprisingly wasn't able to find discussions about this issue.
Actual size is 68.08 mm.
On a nearby aluminium frame it's 68.43mm.
Probably the only solution is to file down the M6 tabs on the motor.
