I'm fairly new to this so I'm looking for some advice. I have the motor on a hybrid bike with hydraulic disk brake and 700c x 40 tires. I have two batteries in parallel right now. One is 35e batteries with only 14.5ah and the other is 30q with 18ah. Not idea but it's what I had sitting around. I needed the extra amps to max out my system. Next is I've got only a 46t chainring (11-36t in the rear) but I've got a 52 on the way. I was able to achieve 45mph on flat ground with peddling and likely could have gotten another mph or two but I got scared. I plan to install 38 wide smooth tires and reprogram the controller to put out 60amps. Ideally, I'd like a battery that will safely put out 60amps. So for those who have been and done this, does this sound like a reasonable setup, am I missing anything. What cadence should the motor be at? I know the no load rpm is way up there, but what's the RPM where the highest power output is?
One last question, I'm terrified of having a tire blow out. Any suggestions for a tire setup that will protect me from that? Thanks
