I just started using my BC168 with some 18650 laptop batteries for a bike project (6 in series). I believe the BC168 can tell me what the capacity is of each battery but I'm having trouble figuring out how to do it. The manual doesn't cover it :/ The charge and discharge appears to work as expected.
I did notice that while charging you can press one of the middle buttons such as Balance and it will flash numbers on the screen that might be total mah stored to the battery so far, is that correct? I'm thinking I just need to wait until the charge cycle is done and press it and record the numbers, but not totally sure that's what I'm seeing. The numbers were something like 0750 for each battery, which seems low for 18650s. I'm also assuming that I'm reading it correctly, with the "07" stacked on top of the "50" meaning "0750". I had initially assumed that the capacity would be displayed on a discharge, but it looks like that's incorrect.
Thanks for any advice!
