gaisom
I am going to be using 8s packs. 18650 Sanyo 2200ma cells
#1 Should I set them up as 4s packs and connect them in series for ease of balance charging and replacing bad cells?
#2 What size balance leads should I be using? max discharge C will be 2amps, and max Charge C of 1amp. I have found lots of conflicting info on this question.
#3 Where is a good place to get the Connectors I will need for the balance board connections using an icharger 1010B+ with the balance board that comes with it?
