derekderek
probably among the most common things us DIY types do. and one with the best chance of really bad results. i have had some luck with those clear heat shrink tubes with ring of solder in em. not crazy about but it works. i also tape on top of the heat shrink and add a slit open heat shrink tube slipped on 1 wire and between both wires and tape the whole mess together. and i also add a fuse holder and fuse right in front of discharge connector if i am in there. then you can work on 2 wires a half inch apart without risking fireworks. but i am sure there are better ways and probably a considered best way to do this. thanks for insight.
