Hi,
The series I am racing in allows LiPo packs with a maxium rated capacity of 1,000 Watt hours. I have purchased 9 of these 108 Watt hours packs that I need to wire together to make my racing pack : https://hobbyking.com/en_us/rhino-4900mah-6s-22-2v-25c-lipoly-pack.html
This will give me a total of 982 Watt hours. For the correct voltage for my system, I need 18 cells in series.
So my set up will be 3P18S. The problem is the nicely sealed packs are 6S.
Are there any advantages or disadvantages to:
A. Running three seperate strings of 16S and only connecting them at total pack negative and total pack positive.
B. Connecting three of the purchased packs in parellel, so 6S connected 3P to make a bundle and then connecting each bundle in series.
C. Disassembling the packs, bundle each cell as 3P and then connected in series 18S. (which would require removing shrink material, disconnecting cells and regen sealing in shrink material).
The cells are rated for 25C but I will be discharging at max of 5C and an average of 1C. My goal is to get maximum energy capacity from the pack rather than maximum power.
