Hello ES community,
Please share your help and wisdom with me. I've recently purchased a Dillenger D5 ebike but I'm finding its top assisted speed to slow.
http://dillengerelectricbikes.com/featured-products/d5-by-dillenger.html
I'm about 84kg in weight, I want to ride it 40km between charges over fairly flat terrain and I'm looking for a top assisted speed of approx 40kmh or better on flat ground.
I've bought the PC programming cable and have fiddled with the controller settings. I'm currently running a "Limited Current(A):" of 14. I've adjust the settings so that it doesn't speed limit me to 26kmh but I'm finding the motor RPM maximum is about capping my assisted speed at about 30-31kmh.
I really like the bike I just wish it had a higher top speed so it can keep up with my peddling a bit more as I feel I'm not much better off than riding my plain old road bike at the moment.
What do you think my best approach would be for increasing the top speed of this ebike? I'm happy to speed up to $400USD to improve this bike.
Should I run more current through the controller than 14A?
Should I purchase the larger Bafang 500W 36V CST rear hub motor to replace the Bafang SWXH6 250W? . If upgrading to the Bafang 500W CST would I also need to get an upgraded controller too that can output 500W?
Any help with this would be very much appreciated
Here are the main electric specs that can be taken from the product website:-
BATTERY
Battery Chemistry: LiMn2O4 Lithium Ion
Nominal Battery Voltage: 36V
Charged Battery Voltage: 42V
Battery Capacity: 10.4Ah
Nominal Battery Energy: 374.4Wh
Battery Cell Type: 18650
MOTOR
Motor Brand: Bafang rear hub motor
Motor Model: SWXH6
Motor Voltage: 36V
Max Motor Power: 450W
Drive Type: Rear hub drive
Motor Sensors: Hall sensor
CONTROLLER
Controller Brand: Bafang
Controller Operating: Voltage 36V
Controller Max Voltage: 36V
Controller Operating Amps: 7A - 18A
Controller Nominal Power Output: 250W/350W
Controller MOSFET Tubes: 6 Mosfet
Controller Sensors: Hall sensor
BATTERY
MOTOR
Motor Model: SWXH6
Motor Voltage: 36V
CONTROLLER
