BH Emotion NEO 36V charge plug
Lorents
I guess this is a long shot, but if anyone know I would be very happy.
I have a BH Emotion NEO 36V e-bike and would like to get another plug for charging the battery (just ordered a Cycle Satiator charger). Do anyone know what kind of plug it is or where I can get one (check attached picture)?
I have found a dongle that I can modify from Scooteretti, but shipping to Norway is roughly $50...
https://shop.scooteretti.com/products/easy-motion-charger-adapter-dongle
The battery is only connected to the controller by two wires. The charger socket has all the wires connected, but I'm pretty sure that only the two power wires are used for charging. The others are for some sort of diagnostics using a special device. You could, therefore, add your own charge socket with a standard connector, by splicing into the two power wires.
Thanks for the input d8veh :)
The connector that I circeled in the picture have only two pins so I was planning on cutting the lead and solder on a XT60 plug so that I can use the same charger for both my e-bikes and EUC's. I was just hoping that someone could point out where to get an extra plug so that I can have the original charger at work and use the Cycle Satiator charger at home.
Worst case I can take just the plug (with XT60 connector) back and forth from work and leave the chargers at home/work :)
