Lussy
Inspired by Timmas frame welding I have 'upgraded' a big hit frame. The more I read and learnt about welding aluminium I became uncomfortable with loss of strength and need for heat treatment to achieve suitable yield levels. I had an alloy box build around the frame and headset with the aim of looking as though it is part of the frame. I then epoxies it to the frame. And repainted in 'gun barrel grey'. The bike is powered by 14s7p of LGD1, build in 2s7p packs with a peak output of 40amps and cruise of around 15amps. The motor is 'upgrade MAC. I made custom battery mounts out of a chopping board and used copper wire braid and bike tube rubber and heat shrink to secure. The jury is still out on the battery pack build by this method, but so far so good. Also linked the internals of the battery box with rubber sheet to insulate in case of a short.
Overall I'm stocked with the final result, just need to finish the battery balance leads, charge port, tidy handle bar wiring and secure the battery box covers......
Cheers Matt
Cheers Matt
