electricmaile
- Joined
- Feb 5, 2016
- Messages
- 14
I'm doing my first e-bike conversion using one of the ubiquitous Chinese rear wheel kits. Supplied was a 26" wheel with a 36v 250W geared motor. My question is whether the wheel (tire) should be centered between the rear forks when mounted and if it's not centered, is this an issue?
About the best I can do, with washers and shims adjusted, is to get the wheel about 4-5mm offset towards the motor side, i.e. the gap is larger on the cassette side. I looked at an engineering drawing of a similar (but not identical) motor assembly and sure enough, it was the same (see attached image). The spokes and rim are centered on the motor, but the motor is offset from the center of the whole assembly (the 135mm between the rear forks). On an unpowered bike the hub (and hence the rim) sits in the center.
Is this something to be concerned about or it it just the way things are. I can adjust the V brake so that it works fine and on a short (unpowered) ride the bike felt OK, even though the front and rear wheels are slightly offset. The wheel runs true (no wobble, so runout) and the axle is square to the rear forks (i.e. the tire is laterally offset, but parallel to the front tire).
I have a reasonable amount of mechanical experience, but mostly working on motorcyles rather than bicycles. I'm just wondering if I'm missing something that's would be obvious to an experienced bicycle mechanic! I've searched the web but not found anything relevant.
Hope this all makes sense. Any help/comments/advice would be much appreciated.
