G’day, does anybody currently know if it’s possible how to remove thecog set, etc. from off an e-bike rear wheel conversionkit to then be fitted in between the front end folks of a tricycle???
I used a 135mm rear hub on the front of one of my bikes, using a 135mm fat bike fork.
One possible hitch is that most trikes use 1" steer tubes, and finding a 1" fat bike fork is going to be a difficult quest. You'll probably need to spread open a 1" fork from 100mm to 135mm and align the tips parallel to each other. A bike shop can do this if you can't or don't want to take it on.
Since rear wheels are generally preferred over front wheel hub drives, a local fb group or craigs list straight swap offer might be fruitful and bypass all the mechanical issues..?
