billsy
Hi new member here.
I recently purchased an 800w ebike kit from a company called Xipi http://www.xipi.co.uk Its a front hub motor kit and included four 12v 12ah SLA's and a 40amp controller. With the SLA's installed, my bike does 31mph without pedalling. The 35amp circuit breaker that was included has never tripped once. The only thing I need to be aware of is wheel spin. Its a fantastic kit.
Now to my problem. A couple of weeks ago I acquired a used 48v 20ah (Ping) duct tape battery off eBay. I have it temporarily attached to my bike and I've done a couple of test runs and no matter how slowly I open the throttle, it is cutting out before I even get to half throttle. The circuit breaker stays on, however to get going again, I have to switch it off then back on to reset. The cut off happens at around 47v Will this be the LVC? At rest the battery is currently at 53.3v. Hot off the charger it is about 59v.
I'm guessing its the BMS that is tripping out is this correct? I've done some reading on the forum about soldering a resistor into the throttle output. I'm willing to give that a go, however as I currently cannot open the throttle more than half way, surely the resistor mod will effectively give me even less that half throttle for it to work? The other option I here about is removing the BMS and only use it when charging. I like the sound of this although I fear my motor/controller will draw to much current from the battery and kill it quite quickly. What are your thoughts on this? At the end of the day I was hoping that this new battery would give me the same, if not better performance then the SLA's. Was I hoping for to much?
Many thanks
Chris
Many thanks
Chris
