bike not running as fast as they did
emaayan
israel
so bike are currently riding 5 kph less then before, when the only changes i've made were
1. fixing the hall sensors (replacing them
2. moving from 4110 to 3077 FETS ( as i have 50 volts battery anyway)
3. moving to ebike .ca
well the hall sensors seem to be working fine, otherwise i would not have worked at all, and since the battery remained the same through both controllers , i can't see how could that affect anything.
so this leaves the ebike ca, while i don't have any limiting features in place, how do i know for sure that throttle range is at it fullest?
direct , but i also have the shunt.
The CA can only limit something if you run the throttle through it. If you connect your throttle directly to the controller, it can't have any effect other than an insignificant drop over the shunt when you use the SA shunt.
i'm mean the ca is connected directly to the controller, and throttle is connected to the CA .
