Hi guys, I have been slowly buying parts to build a bike and ran out of money to complete it
Everything is brand new unused, anyways this is what I have, if there's interest, make me an offer, and I can post pics if there's a serious offer, ideally, for everything.
Otherwise please help me finish it for cheap on an non-million dollar frame, I can't afford that shit
What I have:
Front and Rear 19'' Moped Wheels,
Front tire is not mounted (in hand), Rear is mounted, 25.x inch outer diameter
QS 205 50H V3 5T with the grip throttle 150mm dropout and 12tooth gear if i recall
Sabvoton 96V controller, 120V caps, 150amp version? anyways the higher amp one 120?, with usb or whatever bluetooth accessories
2 x 52V 24.5AH (each) blocks brand new 18650 Sanyo GA cells 3500mAh, 2.55kWh of juice.
2 x 5A chargers for the batteries
I have some random coppers including XT90s. It's ok to run more amps (rated 90 amps), just not continuous cruise at top speed (was aiming for 100-120). I think that's about it. Everything is in its original box except the motor wheel and tire since i had to mount it. plastic still wrapped around the plugs of the motor, nothing ever ran.
Wish I could build it, have been dreaming about it for 3+ years but money... always money
Btw, mounting the tire can only be done at a motorcycle shop, the stem is a motorcycle stem so don't waste time trying to fit anything else.
been lurking never posting, Montreal Canada
What I have:
