g1nko
I know there's lots of advice on here saying you can't rebuild a 48v canbus Bionx battery, but hey, what's the deep end of the pool for if not jumping in foolhardily. My battery wasn't holding a charge anyway (from full charge to discharged in about 3 miles), so I figured "What do I have to lose?"
I took the battery out of the case. This was surprisingly easy. Two screws held the case together. There was some hot glue on one side of the battery and on top, but most of that had released from the case anyway, and gentle pressure with a small pry bar made quick work of the rest.
I'm posting these pics since I figure this attempt to rebuild might be of general interest since I've only found info on the 36v systems. It's a 13s4p pack arranged in 3 tiers of 17 cells with an extra tacked on the side. There are 20 leads to the BMS. I need to figure out how the 13s packs wire together in series; I'm going with the white wires, but I have to figure out the specifics before going much farther.
The 3 tiers have a semi-rigid plastic separator between them. I'm not sure if this is functional or just to help hold things together. I wouldn't have suspected it to be functional, but it's coated with what looks like conductive lithium grease. Anybody have any ideas on this?
