BionX repurposing matching hall sensors with phases
Jeff23spl
Quebec
Hello All
I bought for cheap (50$) a bike with an old bionx (Probably PL250 since it is 24v but i didn't find any tags saying the model....
The guy said it would work with a new battery....It turned out the charger was dead and battery drained itself, I revived the battery for testing purpose and it hold charge but no luck making the bike working. The display don't turn on and i don't get voltage at motor pigtail....I checked connectors and no luck.
Even if i make it works, i will end up with a limited power and locked logic so i gave up with that system, looking into making it more standard with an external controller.
I did watch the video where the guy do it and im in the process of doing the same. I was wondering if there is a way to identify and match winding phases to hall sensors to make it run at first try?
-Is there a standard for color code against position on the rotor?
-Can i follow the rotation order ?
-How can i match the first motor phase to the first sensor ? I mean, is it the closer phase to the sensor that match or something else ?
Otherwise i could wait at the end and swap wires until it works but last time i did try that, it burned a fet of the controller. (I had a middrive motor running backward and my first attempt to change rotation sounded bad for a second until the fet shorted...i found how to properly do it by moving phases AND hall wires, i repaired the controller and it worked...)
Would it help when doing this kind of test to put few ohms resistor in serie of each motor leads to limit current? Or the problem is happening internally and it won't decrease the possible shotrting current ? (i'm doing this unloaded with the wheel in the air...)
Do someone know if the PL250 and PL350 use the same motor with just more voltage or, the motor winding is really made bigger for the 350w model ?
My plan is to run a 12a continious 25a peak controller on it with 36 or 48v battery. A 500-600w continious and 1000-1200w peak. (twice the power) The use won't be extended runtime nor heavy but just a lill more torque and speed would be nice.
Here you go read some of this
Thank you for the option but i have plenty of cells to make a battery, im really into getting rid of everything BionX but just keep motor magnets, hall sensors and windings. It is more like a personnal challenge. Yes that thing have propriatary stuff, controller is on the wheel and battery don't have BMS or anything to monitor individual cells. this is probably why so many fails....it is like they did a lithium pack like a nimh would have been done back in the days...Anyone with original Bionx should look into adding a balancing bms in the battery...
They used a pretty safe battery chemistry that self discharges, IIRC. It's not the standard LCO we use today. Thus the lack of balancing. Annoying how if you leave a pack alone for a year in your garage it will start beeping at you to charge it, though. I've heard the BMS will self brick themselves intentionally if they get too low too. Not a system that's friendly to commodity parts being inserted, unfortunately.
Yes I remember that part but what does the bike look like ?
You could buy those as kids and put them on your bike but they're quite expensive.
Cells really look like standard green 1600mah 18650. It charge to 4.2 and rest at 4.1. im assuming 4.1 because it drained too low. I'm not expecting any good from them but at least powering up the bike to see if it worth to rebuild the pack...But it isn't.
By searching here and there, i came to same conclusion that it isn't friendly and i don't want to spend much money to be stuck elsewhere....I will try to make it friendly if i can.
I'm at the step of removing the gears and opening the motor to fit phase wires and hall sensors wires for a standard controller...
This page seems to explain the whole "LiMn chemistry batteries are self balancing" thing if you want to read more:
yes that what i have. And curiously, those cells seem to accept to be revived after a deep discharge....not sure how good it remain but i will play with them a bit...
Unfortunately, i had to hammer a bit to open the hub motor and it ended up that 2 magnets came off. I sucessfully glued the first one back with crazy glue. That one was marked for the right polarity installation but not the other. When i checked it against another one to figure out the right way, it slipped from my hands and broke into 3 pieces against one pulling on it. I glued the larger part remaining and told to myself it would just make the motor less efficient....but then, i tought about it twice, and remembered the hall sensors crossing the magnets dictate to the controller when to fire the phases....So will my broken magnet take the whole motor down if the gap between that half and the next one is larger?
I checked a bit without success to find replacement magnets at a price relative to the value of the bike...So i decided to give it a try with 1 half missing magnet....
I did a check on bionx controller and used same color for phases and hall number. (1 with 1 2 with 2 and 3 with 3)
I had a hard time to squeeze 3x 16awg phases wires and 5x #20awg thru the bearing but i made it. (I tried 14awg first and there was no space for the halls wires. BionX use just 2 power wires) If i would do it again, i would gring the shaft a little more to gain space....
I did try the wires order i got from bionx with a 45a controller that i had laying around. I put 4ohms reistor in serie to avoid burning something if my phase order get wrong. (Last time i burned 2 fet with a bad order in less that a second.)
Controller was 48v but i don't have a 13-14s pack handy so i did what some would be afraid of, i put a li-on pack with a lipo rc battery to get 48v.....Motor ran at first try. The resistor made it very slow to get up to speed but it was working.
After reading about motor making noise when not at correct order, i decided to try the 5 other wire order for my hall sensors to see if one would have been better...and no....
After going back to initial order, i removed the resistor and everything was good.
It seem that i can hear when it came across the broken magnet or it could be something else but there is a sound at a fixed frequency that came out.
Motor seem very strong....next step is to try it on the bike but i won't use a 45amps controller to burn it...
i ordered a 13/26a kit with pas like the usual ebike aftermarket kit , just waiting for it to ship...
i did try to recharge the pack without balancing mode to see if it self balance like explained in your provided link. It doesn't seem to work on mine...maybe the state of the cell is the reason why but when i recharge without balancing function, 1 group can reach 4.28 when the others remain at 4.1-4.15...I did stop because the group at 4.28 started to rise in temperature...
I tested the pack at about 105-110wh when it should be around 250 new (1.6ax6x3.7vx7s)
I will try to cycle it few times to see if it change and better balance groups....
I'm really surprise: i charged the cells from 0v (completly dead) and cells hold some charge and after more than 2 weeks, there is no sign of self discharging....
Same with ARN123 lifepo4 and it drain itself in a week.
With usual 18650, once it drop below 2.5v or so, there isn't much to do with them other than recycle them...
Some progression so far.: i received and installed a 26a kt controller with display on the bike. I had a hard time with the hall sensors wiring. I used the same color code taken from BionX marking that was working ok with my cheap test controller but it wasn't working with that one. i had a custom connector installed and trying sequences was a challenge, i ended up wiring it directly and found the working sequence with this one. (That KT controller didn't fry with bad halls wiring like my 34a Veyvor one did on a MY1020...)
Then i had issues with the PAS sensor. The way the knuckle is made keep the magnets too far away. I searched in config or tought sensor was bad but it was the distance. It was about 8mm apart...The sensor is bolted into a round support, i used longer screw and a shim to move it closer to the magnets wheel and it works just fine.
Next step is to rebuild the BionX pack but i will try the bike first with a 36v test pack to see the behaviors. Compared to my geared 48v 20a MXus, this BionX motor seem to have a high rpm and just a fraction of the torque of the other. I won't make it a mountain bike...
The free speed at 36v run about 416rpm for 27.5'' tire or about 54.8kmh. 10S is my controller minimum range, i will probably keep it there....Since motor power won't be enought to get very fast, 36v seem the sweep spot. And i could re-use the BionX box and fit 10S4P 18650 in it including square spacers....11S4P would fit too but 10S is more standard...
