Bluetooth added to my controller
I am just wondering is it possible to add a Bluetooth adapter to my current controller? I have a couple of builds I am doing and would like to be able to do this. Or should I just change the entire controller? Which is a larger expense. Any ideas on the cheapest way to get this done.
Since you don't say which exact controller it is, we cannot answer the question.
But first: What specifically and exactly do you want the BT to do for you? Different systems have different features available, so what you want it to do makes all the difference as to whether there is even a point to adding it. ;)
You would also have to specify what you want the whole system to do for you, including the power demands, voltage, current, etc. that it must satisfy, to know if any controller meets those (much less one with the specific features you want in BT).
Saw a couple of YouTube videos which made it easy to adjust your speed. Also I have installed an ebike kit front wheel hub. 36 v with a 500w motor. Has a thumb throttle with power button. No way to adjust the speed through a lcd display as it doesn’t have one. I will post pics of the controller tomorrow.
