ElectricGod
EbikeAus said:Just reporting that the app seems to connect perfectly fine with my new Samsung s9, seems to connect quicker than my old s5![]()
THat's expected...faster phone.
mario1122 said:Here is an app to monitor/control multiple BMS devices in one battery pack:
https://mono.software/2018/11/15/multiple-bms-monitor/
Hi izeman, thanks for your comment. I have checked that accordingly, and you are correct that the top and bottom side of the PCB copper are connected to each other.izeman said:The top and bottom side of the PCB copper are connected to each other. You can see this, because there are small holes with copper inside. You can check that with a DMM. And if this is the case there should be NO PROBLEM to cut out these small rectangles. You will remove a bit of the copper but this should be no problem at all. Especially as you connected two wires on each side balancing the load.
I will cut it accordingly.izeman said:I personally just would cut it. But that's my personal opinion only.![]()
You should add some isolation layer, because you expose the pcb layer to the outside, and you don't want any of the two sides touch the frame or each other!izeman said:I personally just would cut it. But that's my personal opinion only.![]()
tmho said:If anybody knows about the factory contact and website, please advise.
tmho said:Hi ElectriGod, thanks for your comments.
Sorry, I am now in Asia. I will head for the airport for a 6-day trip in Malaysia in about an hour. Therefore, I only have time to post a short reply. But definitely will post more after the trip.
"Can you post the URL where you found this BMS"
I found it at https://item.taobao.com/item.htm?spm=a1z09.2.0.0.57ad2e8do6M27G&id=570909559482&_u=41nfs4840103. But I don't suggest people buying from them because of the poor customer service and not professional enough as I mentioned in my first post.
There is another taobao seller selling the same bms but the price is higher, and the link is https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.100.424374841HYUOX&id=570867089295. And I think sooner or later, there should be sellers selling them in Ebay or Aliexpress.
I am back to Hong Kong from Malaysia.ElectricGod said:Of course if that 100A spec is already overkill for you, then don't bother. If it was my BMS, I'd be modding it. =)
