Fishmasterdan
My Puma motor did that also.
Post up some picture of the case with the large gear on it.
Let see if I can explain with words.
So there is a bearing the axle rides on. Make sure those are still good and have not slipped back towards the windings. If those slip AT all OR the become worn out in any way it causes your whole shaft to wobble only slightly causing binding and gear cluster rubbing. I ended up having to pound my inner axle bearing in (toward the bike dropouts) approx 1/8 if an inch and pound the one way (toward the bike drop outs) that far also.
When there was a problem I could only tell because there was a SLIGHT wobble at high speed and it could be seen at slower speeds.
Sound like it might be an easy fix for you.
