oatnet
I'm bad at being cheap, I keep getting what I paid for ! :lol:
-JD
-JD
hi-powercycles said:Oh yeah, and another thing, I have killed the BMC V4C and BMC V4T on 50A, so don't expect to be pumping 50A continuous up the steepest grades. Most people will not torture the motors as hard as I do, but still 50A on heavy hills for prolonged periods is not recommended for the BMC V4 motors...
I have been using a BMC 1000 watt V4 C with a 50A controller and 2 10Ah 24v (29.4v max) batteries in series. The batteries are rated at 50A continuous. In cold weather the system is fantastic and can manage 56 KPH on the flat with no pedalling. Dropping the speed to 48 KPH halves the watts shown on the cycleanalyst.ebikerbythesea said:Kris B Krunch said:So, anyone out there with some testing on the new v4's?
I think that above the cutout point the throttle voltage may be too high causing a controller input voltage fault. You should be able to verify this on the stand - crank up the throttle and if the controller cuts out you have the problem. If so, I would guess it's most likely the throttle. Is this a hall throttle or a resistive throttle (Magura)?sandymac said:...To best describe this you have to imagine there is a fault in the twist-grip. If you go above a certain point the motor power cuts out, but the Cycleanalyst still operates. ...if I relax the twist-grip and then put it back to just below the cut-out point the motor picks up again. If I hit a hill while holding the twist grip just below the cut out point, the watts can go from say 800w up to about 1300w without a cut-out.
sandymac said:To best describe this you have to imagine there is a fault in the twist-grip. If you go above a certain point the motor power cuts out, but the Cycleanalyst still operates. (I had one of the battery packs battery become too discharged once and everything cut out so I assume its not a BMS problem) if I relax the twist-grip and then put it back to just below the cut-out point the motor picks up again. If I hit a hill while holding the twist grip just below the cut out point, the watts can go from say 800w up to about 1300w without a cut-out. This seems strange to me if there was some over current protection. Has anyone else had this sort of problem? I wonder is it the controller or the motor or even the twist-grip? All advice welcome.ebikerbythesea said:Kris B Krunch said:So, anyone out there with some testing on the new v4's?
teklektik said:I think that above the cutout point the throttle voltage may be too high causing a controller input voltage fault. You should be able to verify this on the stand - crank up the throttle and if the controller cuts out you have the problem. If so, I would guess it's most likely the throttle. Is this a hall throttle or a resistive throttle (Magura)?sandymac said:...To best describe this you have to imagine there is a fault in the twist-grip. If you go above a certain point the motor power cuts out, but the Cycleanalyst still operates. ...if I relax the twist-grip and then put it back to just below the cut-out point the motor picks up again. If I hit a hill while holding the twist grip just below the cut out point, the watts can go from say 800w up to about 1300w without a cut-out.
Gee - that post was a year and a half ago!sandymac said:Thanks for your response.
its a BMC Half throttle (about 2012 vintage)
